• Advertisement
Advanced search
Making IOC and Home Lock work properly
DJI Phantom Quadcopter General Discussion
Moderators: Adam, ElGuano, LuvMyTJ, DeweyAXD, OI Photography, gunslinger
  • Advertisement
The World's Best Personal Drone
Re: Making IOC and Home Lock work properly
Postby deluge2 » Sat Aug 17, 2013 8:13 am
lothman wrote:please help me understand this hole ioc thing. how is it useful and how do i use it. what is home lock and what is course lock and how are they different and when do i use one over the other. also what is the difference between gpi/atti and atti and when and why would i use one over the other. any help with these concepts would be apprecieated
thnkx
bill
lothman@bellsouth.net for email responces
Here something I wrote elsewhere on Course Lock and Home Lock that might be of some interest.
Note the following is consistent with current NAZA firmware/documentation (v 3.16, 2013-08-07) and I think with more recent prior versions as well. Also assumes Mode 2 transmitter setup (ie rudder and throttle on left stick). Note also that the IOC switch by default is not active on a Phantom. You must run DJI's Assistant software to activate IOC function.
In normal flight mode (IOC Switch = Off), the craft's flight response to the right stick ('left/right and forward/back') is relative to the current orientation of the craft. So moving the right stick forward sends the craft in the direction the craft's nose is pointing.
Course Lock (CL) behavior is based upon the craft's previously recorded reference orientation (I'll call this the 'Home Orientation'). The Home Orientation is initially based on the craft's orientation 30 sec after the NAZA is powered up. The Home Orientation can also be set manually by toggling the IOC switch from Off to Course Lock, and back to Off quickly 3 to 5 times.
When flying in CL Mode (IOC Switch = CL), craft response to the right stick ('left/right and forward/back') is relative to the previously recorded Home Orientation, and NOT based upon the craft's current orientation. This remains true no matter where the craft is relative to the Home Point (assuming a Home Point has actually be established) and no matter which direction its nose is pointing. Thus CL flight behavior depends only upon the NAZA knowing the craft's current orientation relative to the Home Orientation in order to figure out how the craft should respond to inputs from the transmitter. This information does not rely on any inputs from the GPS system, therefore CL Mode can be used in both 'ATTI' Mode and 'GPS ATTI' Mode (CL mode will not function Control Mode is set to Manual). And CL Mode does not require GPS satellite acquisition or establishing a Home Point.
Home Lock (HL) behavior is based upon the craft's location 'at the moment' relative to the previously recorded craft location (the 'Home Point') usually established before takeoff as the position of the aircraft when you start the motors for the first time after 6 or more GPS satellites have been found for 10 seconds. The Home Point can also be set manually by toggling the IOC switch from Course Lock to Home Lock, and back to Course Lock quickly 3 to 5 times.
When flying in Home Lock Mode (IOC Switch = HL), craft response to the right stick is relative to the vector (arrow) pointing from the Home Point (usually established prior to take-off) toward the craft's current location (determined via GPS data). No matter where the craft is (provided its at least 10 m from the Home Point) and no matter which way the craft's nose is actually pointing, the tip of this vector represents the craft's virtual nose in HL flight and the craft's responses reflect this fact. Moving the right stick forward causes the craft to fly 'out' (away from the Home Point) along the straight line between the Home Point and the craft's current position. Pulling the right stick back causes the craft to fly 'in' (toward the Home Point) along the straight line between the Home Point and the craft's current position.
Clearly, HL flight requires GPS data (6 or more GPS satellites) both to establish the Home Point and to allow the vector from Home Point to the craft's current location to be determined. HL Mode flight also requires that the craft is at least 10 m from the Home Point, a criterion that can only be calculated with GPS information. When the craft is <10 m from the Home Point, then its flight behavior automatically reverts to Course Lock Mode behavior. Given this dependency on GPS data, it makes sense that HL mode can only be realized when at least six GPS satellites are found and the Control Mode is set to 'GPS ATTI'.
The key here is the distinction is between craft orientation (which way is the nose pointing) vs. craft position (where in 3D space is the craft located). CL Mode relies on orientation information while HL Mode uses both position (GPS) and orientation (compass, gyro, accelerometers).
I would strongly encourage those interested in using these IOC modes to carefully read the DJI documentation and then to perform their own evaluations of fight behavior under controlled test conditions (rather than using IOC flight modes for the first time in an emergency or other critical flight situation). The documentation is helpful, but is not always entirely clear/correct so trust but verify...
Finally, I think the above is accurate, though certainly simplified. If it is inaccurate, unclear, or I've otherwise made some errors (certainly wouldn't be the first time!), pls advise.
Steve
deluge2
Advertisement
Postby Wee Jimmy » Wed Nov 06, 2013 10:49 pm
Just joined from Australia, thanks for the info on CL and HL as I was struggling to get it to work as I just purchased the machine last week, still struggling to use it. It also says to upgrade to 4.2 software and first power off and take of props? Should I do this".......?
Wee Jimmy
Postby Dave Pitman » Wed Nov 13, 2013 12:42 am
Wee Jimmy wrote:Just joined from Australia, thanks for the info on CL and HL as I was struggling to get it to work as I just purchased the machine last week, still struggling to use it. It also says to upgrade to 4.2 software and first power off and take of props? Should I do this".......?
Yes, Firmware 4.02 has a critical bug fix. I have not heard of any new bad things introduced by it.
Taking of the props is purely a safety measure, and is a good idea. Really only takes a couple seconds. The motors shouldn't turn while linked to the software, but you never know.
User avatar
Dave Pitman
Postby miskatonic » Wed Nov 13, 2013 2:23 pm
I pretty much gave up on IOC and Home Lock when I got a Mini IOSD.
miskatonic
Postby Flyboy » Wed Nov 13, 2013 7:17 pm
dbrack wrote:I find HL a little challenging in that it has a radial characteristic. CL seems to make more sense. It flys in straight lines.
At least as I'm seeing it!
db
I prefer CL myself.
User avatar
Flyboy
Postby Flyboy » Wed Nov 13, 2013 7:19 pm
4.02 has been flawless for me. Very happy with it.
User avatar
Flyboy
Postby ironbinder » Sun Jan 26, 2014 11:25 pm
I can't make Home lock or Course lock work on my Ph2 either.
Why is DJI so retarded to do this?
I have a Mac, not PC
It should work by default.
Phantom 2 w/ zenmuse H3-2D gimbal, Hero 3+ Black/ and I have 3+ Silver also.
Immersion RC 600 mW TX, with VAS 5.8 Bluebeam Ultra Airscrew antenna for vTX
FatShark attitude V2's with TrueRC 5.8 Crosshair antenna for vRX
ironbinder
Postby ironbinder » Mon Jan 27, 2014 10:32 pm
But does anyone know how to turn on IOC on a Mac ?
I have DJI Software Assistant for the PT2 for Mac.
It shows that IOC is 'OFF' but there is no button to turn it on?
What is up with this?
please help
-Thanks
Ok, I found out how, for Mac, you open up the PT2 Software Assistant for the phantom, you have to be 'online', turn on your Radio controller first, then power up your PT2, then you hook up the PT2 with the supplied USB to USB Mini cable then go the main 'View' page and in the upper right corner there is a gray button that says 'Phantom' , click it, (that activates NAZA M, mode) then click yes to every other window that asks you if you really want to switch to 'Naza M' Mode. Click Yes.
So then go to the Advanced tab and click the box for Enabling IOC. now you are set. Make sure your lowest atti position is set at 'FailSafe'. There is more to , I just can't remember it all, but you want to do a power cycle when you are all done.
ironbinder
Postby DJIp2v » Mon Mar 10, 2014 3:08 pm
Great information, very clear about the way it´s works, but one question come to me, ¿when do you reccomend to use a course lock during flight?
thanks
Juan
DJIp2v
Postby bernardb » Mon Mar 10, 2014 6:54 pm
DJIp2v wrote:Great information, very clear about the way it´s works, but one question come to me, ¿when do you reccomend to use a course lock during flight?
thanks
Juan
I have found it useful when I was videoing my own house...I set the P2 pointing at the front of the house when I initialize...after it locks onto that position, I fly up over the house and yaw to point the camera in different directions while slowly sweeping from side to side above the house, remaining on a straight line from my initial take off position...really handy when 'tracking' a subject.
Phantom2, Zenmuse H3-2D, Storm FPV, Dji Datalink w/Bluetooth, IOSD Mini
User avatar
bernardb
PreviousNext
  • Advertisement
Return to General Discussion
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot], wattage and 12 guests
  • Advertisement
