It has been awhile since I've flown, but when I did, there was a size limit that you could carry on.mmeither to fit in the overhead bin or under the seat. I don't know the size limit on items that you carry in your lap. With the soft case, that you have, I would not check it in. Airlines are not gentle with checked baggage.
I haven't flown since getting my Phantoms, but if I did, I would use my metal case which came with pre-cut foam, for $99 on Amazon. Absolutely follow what has already been said, carry on the batteries. I would probably remove and carry my Hero camera on-board, too. Especially if it was to be my land camera when not flying.
Also, remember that if you do have a Hero, either carry it or remove the battery. The checked luggage rides at much lower temperatures and much less than cabin pressure. I hate to check any electronic items.
I'm being overly cautious here. Your Phantom and Hero camera were designed for higher altitudes. You could put your Hero in its underwater case, but if checked, technically the battery should be carried on.
However, my air traveling was many moons ago, so rules may have changed. But,if you check it, buy a hard case. Then, you can put it in the soft case at the motel.mmcheck the airline's carry on size limitations. You certainly don't want to be pushing hard to make it fit! Good travels and I hope you get great video.
