KassioLM said:CarlJ said:Reverse the motors and set your axis from 0 to -90.
does nothing!!!
Have you updated both the control board firmware AND the motor's firmware? And have you also calibrated X1 on your TX in your Naza Asst Software?
does nothing!!!
CarlJ said:KassioLM said:CarlJ said:Reverse the motors and set your axis from 0 to -90.
does nothing!!!
KassioLM said:everything is as it should be, updated and configured with gains without vibration the only thing that bothers me is when seto with the knob to -45 to move the phantom when tilting it changes the position of the camera tilt.
exactly as shown in the video below, the of you behave so well? because zenmuze keeps the -45 degrees.
hahah thanks man, but my settings are slightly different in the gimbal gains but what affects most is that my setup is with a Phantom2, software and naza not have more of these options to control the gimbal x1.
KassioLM said:Friend, solved the problem, I made a downgrade to firmware 1:08 ower possessed these options and changed the setting now gimbal responds perfectly in mode 2 and the camera no longer changes its initial angle. then did the update again to version 3.2 and everything worked perfectly, thanks for the tip ...
ageedb said:Kassio, I just got the adapters that you used and im now trying to install them. How did you? I'm not sure which way it goes. Could you post a close up picture of how you have it setup? Thanks!
Did you use an adapter or did you just drill an extra hole?
