Peter Evans said:I use '3M Dual Lock' for this purpose. It works a treat and the Phantom flies fine with the prop-guards attached this way.
All you need to do is cut away the projections on the inner side of the prop-guards where the machine screws pass through before you stick the Dual-Lock to them.
For added security (if you didn't trust the holding capabilities of the Dual-Lock's sticky back) you could always use machine screws through the Dual-Lock pieces themselves
Lenny7118 said:What do you mean by cutting away the inner projections on the prop guards? Do you have a picture of that section that needs to be cut away ?
Peter Evans said:Lenny7118 said:What do you mean by cutting away the inner projections on the prop guards? Do you have a picture of that section that needs to be cut away ?
No I don't have photos sorry (because on the photos I have, I've already cut them off!) but each prop-guard has two projections around each of the two screw holes (on the inside ). When you screw the prop-guard on these projections fit into two depressions around the receiving holes on the underside of the Phantom's arm-ends. However, if you're using the Dual-Lock method, you need to cut these little projections off otherwise you don't have a perfectly flat surface to stick the Dual-Lock to.
MonsieurAnon said:If someone can send me measurements and close up photographs of the interior hole, where the screw goes, on the prop guards, I might be able to come up with some kind of quick release mechanism for them.
Phantom_Menace66 said:MonsieurAnon said:If someone can send me measurements and close up photographs of the interior hole, where the screw goes, on the prop guards, I might be able to come up with some kind of quick release mechanism for them.
I'll ask the girlfriend but I don't think she'll let me photograph her! Bah ha ha
I got to thinking about your set up. Why couldn't you cut holes in both pieces of the Dual Lock and not cut the projections off the guards. That would allow the dual lock to lay flat and keep your guards as a stock item if you ever wanted to sell them to some one else. The projections would just go into the holes in the arm, to some extent, and not cause any problem.Peter Evans said:I use '3M Dual Lock' for this purpose. It works a treat and the Phantom flies fine with the prop-guards attached this way.
hdlicht said:Quick Release system for DJI Prop Guards.
(stated as working on all models of the Phantom).
Atlanta Hobby is now selling a quick release system for the DJI Prop guards.
A bit pricey, but they look very interesting and seem to solve the problem.
http://www.atlantahobby.com/store/pc/vi ... category=0
The devices are actually being made by AfterDarkLED.com
I have ordered a set and will respond back here, once I have a chance to evaluate them.
Mori55 said:I just check Atlanta hobby, was going to order until I saw the shipping !! 12.00 to NJ , that's crazy , out of control gouging ! Christ I can get stuff from China cheaper.
Happyflyer said:I got to thinking about your set up. Why couldn't you cut holes in both pieces of the Dual Lock and not cut the projections off the guards. That would allow the dual lock to lay flat and keep your guards as a stock item if you ever wanted to sell them to some one else. The projections would just go into the holes in the arm, to some extent, and not cause any problem.
It's the point, how many times have you passed buy a item on eBay with a ridiculous shipping charge ? These are small items you can put in a packet and ship for 5.00.shrill mute said:Mori55 said:I just check Atlanta hobby, was going to order until I saw the shipping !! 12.00 to NJ , that's crazy , out of control gouging ! Christ I can get stuff from China cheaper.
Whining about $12 shipping = awesome.
Thanks.
Big Ben said:I like the dual-lock method but I do wonder how much 'give' the prop guard have when attached this way. Will they be able to withstand a substantial hit/crash without themselves being moved into the path of the rotating props?
