- Joined
- Jan 15, 2017
- Messages
- 68
- Reaction score
- 12
- Age
- 37
Ordered the Argtek Today and I've watched a few installation videos. Curious on what everyones thoughts are on leaving them inside or removing them ? Thanks all !
If you don't think 1250ft is very far try this trick. Fly out to around that distance, fix your eyes on the phone screen and move the sticks to change the drones postion, one second should do. Now look up and see if you can spot your drone quickly, its amazing how tiny a dot it becomes when you lose visual track for even a second or so.Do you see a big change ? I'm out in the country here in Maryland. I've taken it out stock to 1250 ft with perfect video feed and connection but I got nervous haha...1250 isn't very far it seems.....
I just installed my Blueproton ARGTEC last night & I also took them out & had the same issue as above , the OEM Panels were glued in on one side, plus the Sealer that was used . That sealer was easy part to remove , but even removing it , that one side was glued in some way & I also broke a little of the Green backing plate off .
I also had issues with installing those little connectors on , cutting that white sealer off & removing the OEM ones was easy , putting the new ones on was more difficult .
I installed the short GRAY one first & it barely had enough cable to reach that first connector , the BLACK one , I could pull a little more out of the Antenna manifold & the WHITE longer one , had plenty of cable , more then enough .
I have not tested the with a flight yet , but will later today ,if I can .
I didn't get this upgrade for distance , but for better reception , though I will have to see how far I can go at some point .
Good luck & as was said ,,just take your time .
Looking forward to your results!
