Pigtail pulled loose from the gps board. Not sure where to resolder the leads. Lower board or upper board or both ? Thanks .. been looking for schematic. . NO such luck. It's a DJI Phantom 2 , GPS ..= DJI 11-22 V2
Hello Jeffery,
I'm not sure I understand, did the wires come loose from GPS puck ( part under top shell? Or did it break on phantom mainboard?
Do you have a pic?
If it is the GPS puck, wire attach opposite ceramic patch antenna, if mainboard underneath ( depending on how it broke ) might be only option to solder it top side? As long as connections, make connection, it should not matter, just be careful, not to create a solder bridge across connections. ( as it would possibly short something out. ).
If you have a picture, I'm sure we could better help you!
Keep us updated! And the best of luck on your repair.
