My Phantom 4 Professional (with Display) arrived today. I have owned a P3 Advanced and still own a Phantom 4 and Yuneec Typhoon H Pro. I have a Parrot Disco coming my way tomorrow for giggles only.
After unboxing and charging all batteries and controller, I updated all software/firmware on the Controller/Display and then used my Mac to download the new Assistant, calibrate the "cameras" (obstacle avoidance). Every time I did a firmware or there calibration or update. I shut down both the controller and aircraft and then restarted. I had no issues with the software/firmware update using the process I just described. I took it outside for a test flight. I calibrated the compass but could not find a way to calibrate the IMUs. I calibrated the gimbal.
Started up with no problems. Initial few minutes were in a very close area no more than 4 feet off the ground, to make sure all was 100%
Climbed to 200 then 400 feet (slowly and cautiously). I headed to a spot where by P4 loses all signals 2000 feet from the launch site with plenty of trees between us. My P4 DOES have those copper things slid on the two antennas to "focus" the signal and my P4P does not (yet, it's coming) I had no problem reaching this site 1/2 mile away with excellent signal despite the trees (forest) between us. So, I found much better reception between my P4 and P4P, favoring the P4P.
Excellent to the inch stability in moderately high wind.
Flew back and explored the opposite direction for about 1500 feel away with houses and trees between us.
Came back and chose a round "picnic table" that in summer had an umbrella in it as my favorite landing place. Now just the hole in the center and no umbrella.
Hovered over it and using VPS on the very good texture, it was again to the inch steady, despite some wind. I then landed on the table. The stability over the table is noticeably better than my P4. And much better than my Typhoon (which is now at the factory to check out it's lack of rock solid hover),
I love the P4P and as you can see, I am a stickler for detail (I am "big" aircraft pilot as well and have been for 40 years.). Same philosophy: Dot every i and cross every t. I don't just kick the tires and light the fires.
These "drones" are not toys. It takes real attention to detail not to have a disaster on your hands (and maybe someone else's).
Again. no problems with updates, firmware bugs etc like some of us are talking about here.
PS; I did sign up for DJI Care/Refresh.
