P4P Battery question?
Does anyone know what happens if a Phantom is allowed to run down battery until it goes into auto land at say 200ft in the air? Does it know how much battery at that altitude it will need to descend all the way down softly? Or would it just fall out of sky after so long. What if bird was say 400ft or even higher? Just curious to know this one.
It doesn't know for sure since the Phantom has no idea where the ground is located when it's high up in the air. If the elevation of the ground at the Phantom's current location is fairly close to the elevation at the takeoff location, then it should make it to the ground in time.
Reactions: KevMo Photog
If the wind is not very strong, phantom can definitely land safely with 10% remaining battery charge assuming battery is in good shape. I usually raise the critical battery level to 15% for old batteries just to be safe.
Ok, so your saying that as long as it close to takeoff altitude it should be good. So if was not, and it was say 400ft above takeoff then your screwed right. Cause it's gonna take longer to get down from that height than 10% will give you?
I'm talking about a case if the bird was right over your head at 400ft and the battery goes to 10%. Will it land softly or will it fall out of sky?
it will land softly, as bird will go into auto land depending at what % you set it at
If you want to keep the Phantom, aim to be on the ground by 20%.
The day you are cutting things too close is the day you can count on complications.
Totally hear ya Meta4! I've only been below 20% maybe once or twice. I'm always back in close by 25 or so. But I was just totally curious what happens in a weird case and the bird was a total disconnect and was way up like 400ft. Love to know the what if's. LOL
I'm assuming DJI has added some kind of buffer to account for possible altitude differences. You're going to be screwed at some point though. Like anything when it comes to flying Phantoms, you're always going to be better off by not fully relying on its automated systems.
jrl
