Bought a store return motors don't start has all red lights after a few yellow green seller said it had an obstructed motor & while having it upside down a small screw fell out was hoping that was the obstructionWhy are you trying to open it?
It says Phantom 4 will it still work?If you're trying to install new firmware, you can find detailed firmware installation instructions here.
Don't think the firmware will fix it.
You don't run the bin file on your PC, you put it in the root of an SD card and SD card inserted into gimbal.
Try relinking the RC to the AC.
Bought for parts or as isWhere did you buy it from? U should return it immediately and this time u should ask for one that's not already f***** up.
You don't open the file or run it on your computer. See posts #2, #3, and #6 above for more info. Post #3 has detailed information.Here's what I get after downloading then trying to open it says Adobe reader could not open file P3x_FW_Vo1.09.0060.bin because either not supported or damaged
You would see it on the Go app on the Android/ios connected to the RC which in turn is linked to the AC.Not sure I understand this is all new to me how does a person check their Phantom & say it has an ESC error or a obstructed motor for instance I am on a pc only & not a youngster so this is a learning experience
