P3P antenna placement help
NE Georgia USA
I am in the process of replacing the body shell on my P3P and did not realize that the antenna modules could be taken out thru the leg holes. I removed the cables from the board after colorcode marking them. What I did not do was mark which leg they went to. I notice that each one has a number 1-4 on it. Is there a certain order they go in the legs and if so where is #1 and which direction do the go (CCW,CW)
I do realize that the 2 with longer leads go to the legs furthermost away from the board. I did replace the legs also.
Thanks in advance..
Julian
OMG you made a blunder hahaha
Following are the numbers to be followed up:
wkflysaphan4
