I'm not hearing that the home point is set when I state the bird? Isn't it supposed to be doing that?
Airport mode shuts all apps down while dji in use cuts out extra interference,,mine used to talk heaps aswell,,calibrate compass ,,it might wake upNot familiar with airport mode? I'm in the basic F mode
Really? The home point is set from the GPS from the AC.... I'm pretty sure my home point gets set when I have no cellular connection in the middle of nowhere, even when there is no map loaded.Are you using an IPad wifi only by any chance? If so, that's why.
Fact.Really? The home point is set from the GPS from the AC.... I'm pretty sure my home point gets set when I have no cellular connection in the middle of nowhere, even when there is no map loaded.
Yip i have to agreeReally? The home point is set from the GPS from the AC.... I'm pretty sure my home point gets set when I have no cellular connection in the middle of nowhere, even when there is no map loaded.
Sorry sorta meant that but did not explain properlyi got away from wifi so i didnt take into account what phantom he was flyinNo it doesn't, it just shuts off any radios — Wi-Fi, Bluetooth and cellular functions.
Turning off cellular may be a good idea to avoid incoming calls during flight, but you might want cellular data for maps, and depending on the model of drone you're using you may need Wi-Fi to fly.
