New Drone Setup, No signal Error, and YES I've tried relinking a dozen times.
Hi all,
Great there's a forum with such knowledgeable people available.
Got a new Phantom 3 Standard.
Everything's charged, and powered up, but after a firmware upgrade the rear LED's started blinking yellow, and a no signal error was at the top of the DJI app screen.
I'f tried both using the relink button while pulling th gimble left and toggling the S2 switch. The controller beeps with a red light and then goes green but the aircraft still blinks yellow in the main rear LED lights, and solid red in the link button. I've also tried relinking using the apps relink function, same result.
I uninstalled and then reinstalled the app, and nothing seems to be working
In the home screen when I view the available Firmwares it says I can't downgrade. I'm using a Galaxy S5 with android OS.
Anybody have any ideas. All the videos and forums I've been able to come across give the same advice of relinking the aircraft and I know there's something more.
Try connecting to your drone without an SD card in.
Also: try connecting your SD card to your computer and removing/deleting all but the trashes folder on the card.
Then, once you're done with that, put it back into the drone and try restarting and connecting to it then.
If it works, remember to reformat the card (can be done through the dji app).
cokersean20
