- Joined
- Mar 20, 2017
- Messages
- 3
- Reaction score
- 0
- Age
- 41
one motor on my p3 standard stop spinning with the others but when I turn on the unit that same motor moves(twitch) then stops.... what's my next step?
either A: motor is shut or B:ESC on the main boar is burning out.one motor on my p3 standard stop spinning with the others but when I turn on the unit that same motor moves(twitch) then stops.... what's my next step?
found the problem with the battery error! it was a small two wire plug on new main board that i did not completely push connector into its slot for fear of breaking the new board. The cable comes from the 4 pin connector at the battery connection.yes esc most likely bad, do u get an esc error when starting up? I had the same issue, replaced board and now getting battery error. not sure if i need to update fw or what?
