Whenever I boot up the p4p indoors everyone moans as it kills the internet
Someone will have to clue me in here.
How does the connection between the RC and the drone have anything to do with the home router?
I can see it accessing the maps for a short while, but once that's done, where does the drone/RC combination hit the home wireless network?
AD
They both operate on the 2.4gHz and/or 5.8gHz frequencies. Normally the wifi drowns out the drone, not the other way around. That's why you get much cleaner signal in the country than in the city or suburbia
That works for me the problem it's that the router switch to a cleaner Chanel when there it's noise where it's transmitting but the drone does the same so the both keep changing channels non stop until the router give up and get stock ... I set the router in 1 channel normally 7 and then the drone will stay automatically out of that channel becuese it's been use ... no more cross noise ....Try changing the channel setting on your router from Auto to channel 1, 3 or 11 and see if your situation improves and let me know. Where do you launch your Phantom in relation to your router? Does your WiFI network usually reach outside of your home?
Take care,
Jesse
Never had any problems flying from home, it just knocks the wireless router out, I could like you say change the channel and see if that helps, or just let the family moan they can't connect to the internet
