H3-2D Directions - Straight Down for Photos?
Discussion in 'Zenmuse H3-2D GoPro Gimbal' started by kburrows, Feb 3, 2014.
  1. kburrows
    I know this is a silly question. I am just getting into quad copters and can't find out anything about the maximum rotation of the H3-D2 gimbal. Can it point straight down to take a picture? I assume the only way to do it with the GoPro 3+ is to set the camera to take pictures at a set interval and hope you don't run out of space on the micro SD card. Of all the videos I have seen posted, I have noticed there are none with a straight shot down.
    Thanks!
  2. ladykate
    Bellevue, NE
    Yes, you can aim straight down. I have a few videos if you want to see them. Some others have posted videos that were wholly straight down. I usually set it up so the horizon is not bent too much. The fish-eye makes some significant distortion of the horizon at times. Aiming the camera correctly helps.
  3. kburrows
    Good news! It's amazing how little has been posted about the actual use and function of the gimbal. Just how to install and calibrate it. I have Photoshop and GIMP to remove the skewing. Adobe now has the Hero 3+ in it's camera database, so getting the pin cushion out should be much easier now.
    Thanks for the help!
  4. kburrows
    Would love to see your videos. How can I get a link?
  5. ladykate
    Bellevue, NE
    Here is a short clip that shows the camera pointing straight down. I usually cut this part out of the videos. ;-} When the camera pans up you can see the horizon distortion straighten as the camera and the horizon line up. If the camera was pointing down (or up) farther, then there would be distortion of the horizon. There will always be distortion somewhere due to the wide lens but even in superwide mode, you can still affect it by using the FPV and aligning the shot so your target is less affected by the fish eye.
    [youtube]http://www.youtube.com/watch?v=Q6vbX0jU3cE[/youtube]
    Here is a view of a building (you can see it on the left it the above clip). Note that the distortion due to the fish eye is minimized by positioning the airframe and the gimbal.
    [​IMG]
    Here is a version that emphasizes the fish eye
    [​IMG]
  6. kburrows
    Excellent! Thanks for the video and pics! What program do you use to reduce the fish eye and what settings do you find work best to reduce it?
    Thanks so much!!
  7. ladykate
    Bellevue, NE
    Those are unprocessed shots. There are some packages you can use but I prefer to do what I can with the camera angle.
  8. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Watch this short -> https://vimeo.com/85627492
  9. kburrows
    Thanks! I spent a long time on line trying to find specifications for the gimbal and just couldn't find anything that showed the range of movement. Watched so many videos I got sea sick with the motion. I guess most are going for the dramatic cinematography with the sweeps and flying low.
    Good job with the video! How many sea lions did you chase off? :D
Similar Threads - Directions Straight Down Forum Date
Phantom 3 standard changing directions on mid flight Standard/4k Discussion May 13, 2017
Directions or diagram for wiring amps to a ItElite setup on P3S Standard/4k Discussion Feb 15, 2017
Sport mode, same top speed in all directions? Or only fwd? Phantom 4 Pro Discussion Dec 17, 2016
Phantom 4 Vibration Absorbers Set Install Directions?? Phantom 4 Discussion Apr 8, 2016
P1 not moving in directions i move sticks Phantom 1 Help Aug 15, 2015
