Anyone know how to turn on the Wi-Fi Autonomouly on the go Pro?
I want to test mine see if it has that problem, but just shaking it doesn't do it.
Maybe I'll set it on the washing machine?
I have also seen the case where once the GoPro is in the Zenmuse with the Wi-Fi on and the Phantom powered up; if you turn the Wi-fi off by pushing the button, the blue led will flash a couple times and then it will go off. But a few seconds later will start flashing again. After repetitive attempts to get the wi-fi to shut off I finally pulled the battery on the Phantom and then it was able to turn off.
I produced somewhat similar results trying to turn the wifi off by pushing the button on the side when the GoPro was turned on while charging. It responded the same way.
