The P4 is down to $1199 on Amazon, and $999 plus 8.99 shipping from one of the Amazon Marketplace vendors.
Amazon.com: DJI Phantom 4 Quadcopter: Camera & Photo
Nice video. Garish house.thanks for the input guys.
Here is a sample of a house I just finished today. Been filming and editing for the past 3 days.Done on my Q500+
Getting close to pulling that trigger on a P4. Been flying a yuneec 500+ with the 4K cgo3 camera for the past year with no issues. Still on my first set of props. No crashes or mishaps except for that tilted horizon this seems to show up every couple of months. Im on my third camera now. Im seeing DJI has the same tilts at times. Strange that both manufacturers have the same issues. when it comes to that dreaded tilt
How many P4 owners have had this issue or other problems causing a return. Thank god for knowing the owner of a drone webstore as they have swapped out all my cameras when this has happened even after the warranty has run out. Things Im liking in the P4 are many,most my Q500 + dose not have and I have read both pros and cons of the new hex-copter the H from yuneec. This is why Im looking at the 4 really hard. I can always save my Q500 as a backup. Should I pull the trigger on the P4<<< You guys are suppose to talk me into this right?
Also had the option of getting a inspire 1 open box for about 500 more but I just do not like the size when transporting it around to do video shoots of real estate. One reason Im liking the 4 is the easy transport and is prop install are some of the reasons
Honestly. I would wait until your man enough to make your own decisions. Then get what you want
I would not touch a DJI product if it were free! I'll keep my 2 P2V+'s buy the next one will be another brand. Having recently tried to fix a friend's crashed P3Pro and seeing the weak inside design I would not buy DJI again. They are making individual part replacement almost impossible and the main board mounts all sheared off from a 30' drop. If they beef up their design I would reconsider.Getting close to pulling that trigger on a P4. Been flying a yuneec 500+ with the 4K cgo3 camera for the past year with no issues. Still on my first set of props. No crashes or mishaps except for that tilted horizon this seems to show up every couple of months. Im on my third camera now. Im seeing DJI has the same tilts at times. Strange that both manufacturers have the same issues. when it comes to that dreaded tilt
FYI, those four screws in the P3p that hold the main board in place were designed to shear off the board mounts on the battery tray, intentionally, so in a hard crash the main board doesn't fracture. The $8 battery tray is the sacrificial plastic part, easy and cheap to replace, saving the main board.They are making individual part replacement almost impossible and the main board mounts all sheared off from a 30' drop. If they beef up their design I would reconsider.
I totally disagree! When they sheared off it slammed the board into the cover ripping off components. That board is to small to suffer a crack from a 30ft drop if it was shock mounted and not mounted with weak plastic stud.FYI, those four screws in the P3p that hold the main board in place were designed to shear off the board mounts on the battery tray, intentionally, so in a hard crash the main board doesn't fracture. The $8 battery tray is the sacrificial plastic part, easy and cheap to replace, saving the main board.
Been there, done that. I like that design feature.
OK fine, we disagree. We can guess all day long about what works best and what doesn't, and at what cost.I totally disagree! When they sheared off it slammed the board into the cover ripping off components. That board is to small to suffer a crack from a 30ft drop if it was shock mounted and not mounted with weak plastic stud.
What I would like to see in general since DJI is making it near impossible for you/me to repair it by moving all components to one board is a beefed up design. I know plastic is plastic but carbon fiber in areas could help structurally. Dude I don't know about you but watching $14-1600.00 or more fall from the sky and crash is more than depressing especially when you don't have the bucks to keep buying them. I understand business and no one wants to make these to last forever hoping for the parts/repair business to add $ to their bottom line. I am a huge fan if they would incorporate from the factory a functional parachute...self deploying. Have a great day...safe flying to you.OK fine, we disagree. We can guess all day long about what works best and what doesn't, and at what cost.
I had crash from about 30' up tumbling through a tree, down onto blacktop (stupid bird, feathers everywhere). My board sheared those 4 mounts, but after testing it the board integrity was good. It's flying today. I was pretty impressed, appearing to shear off intentionally, for moderate crashes. There's no telling if the board would have been fractured if it didn't "give way", but IMO the shearing of the mounts helped the survive-ability of the PCB, more than rubber mounts would have. And yes, they do look like weak mounts, but I believe that's intentional. Had the board got broke it would have been cost prohibitive to repair my P3P, but in this case it only cost $305 (4 motors, 4 props, new body shell, battery tray, landing gear, camera cable, gimbal mount + $90 labor). The P3P is a clever internal design in this subtle way, IMHO. I suppose DJI learned this trick from the P1 and P2 designs, my guess.
well guys,,with the price drop on the P4 Im going to go ahead and get one. I'm on my third camera on my Q500 for the horizon tilt. Im just waiting for it to do it again. If anything I will keep the CGO3 camera on the steady grip for my fly through the door feature.
