- Joined
- Jan 1, 2015
- Messages
- 27
- Reaction score
- 0
Burl my friend. My english is poor. Can you explain this for me?
Snugged ? Spun? How did clean and got better range ?
can you explain this a little more please, Jeremy? Thanks.burlbark said:hangtensoul said:Guys. I just came back from the tests. Did the new hole to make sure the cable is not curved ...clean up round the chip and fixed it well. Not good. 600 meters and signal lost... I had some conexion broken too and i was aiming the phantom.
I really apreciatte the attention of you guys. Thanks anyway.
Richard what is the washer from the bulkhead ?
Do you guys think i should put the pinwheel cable that comes from the radio out of the radio ? I mean out of the radio to make it easier to screw with a wrench ?
If you guys could send me pictures to know how your radio is would help me ...
Thanks guys.
600 meters is not bad... Depending on interference. I have been having some problems also. I was able to narrow one problem down today that gave me allot more range. The SMA connectors, both the male pin and the female receptacle may have contaminants on them that dont allow full power. I was getting dropping signal at 75 yards with the Vision on the ground. I snugged the nuts down lightly on the tx side connectors and spun the antennas. This rotates the pin in the sma connector and removes any residual solvent or flux that may have solidified on the contacts during manufacturing. I was able to step off to nearly 150 yards before terrain and brush compromised line of sight. Nearly double the range and I am sure without ground attenuation that would amount to allot in the air. I have high voltage transmission lines near me so I cant take it out that far.
hangtensoul said:Burl my friend. My english is poor. Can you explain this for me?
just turn it 2 times in the socket,hangtensoul said:Understood but what is a couple of revolutions ?
Just couldnt get that ..
hangtensoul said:Hello guys. I would like to thank everybody that helped me here ... Really really thank u.
My problem was the connectors that goes straight in the hardware inside of the radio controler. The pins were smashed inside and thats the reason i couldnt go farter then 350 meters. I changed all the wires and tryed to connect it in a safe way. And i did... I went to a place witch is rounded by buildings in a lagoon and i got 800 meters that i never could before. I will try in a farm or a bettee open area but i can see the problem was in that connector.
Thanks Tony for the support.
Any question im here !!.. Bye
