This HowTo will advise on how to enable encryption on the FPV WiFi, but ONLY the one between the repeater and your FPV device! (Encrypting P2V+ to Repeater comms takes a bit more juggling, but I'll write it up tomorrow.)
Via Command Line:
Please use the WebUI method below. There are too many ways to mess up the only means (your wifi connection) you have of fixing the Repeater/Drone if you're on the CLI.
Via WebUI:
Enjoy!
LK
Via Command Line:
Via WebUI:
- Install the WebUI per THIS THREAD
- Log into the WebUI at http://192.168.1.2 with Username root and password 19881209
- Click 'Network' -> 'WiFi'
- Click on 'Edit' next to your 'Phantom_XXXXXX' WiFi
- Scroll to the bottom, Under 'Interface Configuration' click on 'Wireless Security'
- Select the Encryption of your choice from the 'Encryption' drop down (I strongly recommend WPA2+PSK)
- Select the Cypher of your choice from the 'Cypher' drop down (I strongly recommend Force CCMP (AES))
- Type in the password of your choice in the 'Key' area
- Click the 'Save & Apply' Button
- Wait for the WiFi Repeater to reboot, and reconnect with your newly encrpyted WiFi network
- After the Repeater boots, re-connect to your newly encrypted FPV Repeater WiFi using the encryption standard and password you picked!
Enjoy!
LK
