I got out to 14,000 ft on a later run. I added the DBS Itelite antenna to my RC. It's a wide open unobstructed view out over the lakeHow did you managae to 1200 ft?
Im really interested
I've not tried it anywhere else yet. Could be that my situation is optimum in almost every way. I have no houses near mine so my controller won't get much interference (I should try turning off my own router to see if I get further ) It is well above any houses on the way to the lake and then it's over open water. No line of site obstructions whatsoever.i have dbs my maximum is 6144ft lol
Not sure where in which video. But I'll have to look the next time I launch it. Bear in mind that I think there was a pretty good breeze on those long flights. Also I've noticed myself accidentally applying side pressure on the stick at times.do you notice at all you pahntom drifts ever so slightly after letting oof the forward stick?
After watching your video i notices a couple of times it looked like you bird was moving on its own to the left, only ever so slightly but mine also seems to do this at a big distance from me
Very, very good. I've made it to over 16000' once, but that's with amps too. Going over a big lake has to help a lot. What FW are you on?I got out to 14,000 ft on a later run. I added the DBS Itelite antenna to my RC. It's a wide open unobstructed view out over the lake
I think it's 1.5.70 or somesuch. I did a downgrade to a recommended good version A little while ago .Very, very good. I've made it to over 16000' once, but that's with amps too. Going over a big lake has to help a lot. What FW are you on?
That was a good FW 1.5.7, wish I stayed there.I think it's 1.5.70 or somesuch. I did a downgrade to a recommended good version A little while ago .
Nice job that was a nice flight. Great song for the video too. I'm curious as to what software did you use to edit and add the music?Not really in this case. Here is the video. I sped it up so the yaw motions are more jerky than usual. I need to work on that.
Thanks.Nice job that was a nice flight. Great song for the video too. I'm curious as to what software did you use to edit and add the music?
