what do you think how many hours can full charge?As far as I know yes you can it will just charge a little slower as it's 57v rather than 100v will still work though as it's exactly the same battery
thanks buddy i appreciate thatThey are the same batteries, just different chargers. Mine take approximately 1-1.25 hrs to charge on the standard charger if they are below 30%. Since I don't normally let them get that low or are in storage mode, it takes 45 minutes to an hour.
so in this case buddy can i use the charger in my phantom 3 standardThe DJI 57W charger with the P3S does not charge any controller at all .... it has no plug or connection for it. Only the 100W DJI power supply has plugs for both Controller and Battery.
But both the 57 and 100W chargers can do any of the Phantom 3 batterys without problem.
Nigel
thats a good explainable but i am poor in math when i was a student i have a failed in math thats why i hate it hahaha cheers mateIt's current that recharges the battery.. not wattage (wattage just "pushes" the current), so you can't expect a 100w to charge twice as fast as a 57w. There are other factors in play (Ohms) The 57w puts out 3.3a and the 100w about 5.4.
1000mah's = 1ah (amp hour) so a battery with a 4480mah capacity holds 4.48ah's. A 3.3amp charger is pushing 3.3a/hr. The 5.4amp charger 5.4a/hr. Depending on the current SOC (state of charge) of your battery, and doing a little basic math you should get a "really" good idea of what you're charge time should be. Ie., 50% soc=2240mah (or 2.24ah). On a 5.5amp charger you're looking, loosely, at around 20min. (not factoring in bulk/absorption rates) Close enough for horeshoes and hand grenades.
..Battery charging put simply is just not a simple capacity / Amps calculation. That is why people expecting to charge in 30mins end up waiting 40mins or more ...
