I'm not sure what an absorber board is. Are you talking about the board inside with all the electronic stuff on it?Thanks, do you think the crack in the absorber board that is glued would cause the camera to act up.. I don't want to rip the camera and gimbal apart if it's the absorber, I will just wait for the replacement to come in,l.
That should have nothing to do with the camera operation. If you glued, soldered, etc it back together. I believe your horizon was knocked off in the crash. The half moon shaft I was talking about.No. it's the x shaped plate on the belly of aircraft, that the gimbal mounts to.
I would suggest talking to Hunch then. I have worked on mine, but the difference is my is here, and I can see it. Yours is there, so I'm clueless as to what happened to it.It looks ok
