- Joined
- Nov 24, 2016
- Messages
- 434
- Reaction score
- 110
- Age
- 34
1. When you set the p3 batt to discharge say on x-amount of days.. How exactly does that work?
will the count basically begin after the first day it's not touched? Or not used? Like is it based off when the drone/battery was powerd up last I take it? So if I powerd on the battery last night, then it will start the x-amount of days count down with in 24 hours After it was last powerd up?
2. I know we can shoot pics in single shots or burst, but wouldn't it be an even more detailed image if I were to just take a screenshot of the video playback directly off the sd card? I have a p3a, so if I took a screen shot of a video, it would basically be a still image in 2.7k.. So wouldn't that be better detailed than a 16mp still picture? Or is it not as good..?
3. When setting the low battery warning.. If I set the warning up to say 35-40% vs stock 30% will the craft I
Enable rth sooner? Or will it still only rth at 30%? Cuz I thought about setting it up to 35% cuz I often go out far and would like that little extra time for my battery to make the trip home incase of high winds or some other issue I may encounter.
4.in advanced settings there is a blue button -enter flight data mode- what exactly is this used for? Is it for when you are on the dji website or healthy drones, you connect the USB from the quad directly to your PC and click this button? Or is it for something totally differnt.
5. I know the USB on the quad itself is for flight data, does anybody ever use this method to transfer the flight data? Or can you just as easily transfer the data to dji website or healthy drones through browsing/uploading directly from the device that you use for fpv/dji go.
6. Are the stock props the best props? And are carbon fiber props the ONLY other prop that will work with the p3? Is there something better than stock? I'm not a huge fan of the cf props as they are very stiff and will make the aircraft not as fluid though the air
